Man, that is definitely on my list to do when I reskin mine. That window is awesome!
I’m telling you man they rock. No need for sealer either. It has a nice soft rubber gasket for the outsideMan, that is definitely on my list to do when I reskin mine. That window is awesome!
Did the window come with a template to cut the hole? So there are no screws holding it in place just the gasket?I’m telling you man they rock. No need for sealer either. It has a nice soft rubber gasket for the outside
Ahh I see. Do you think the gasket would work with corrugated siding? We have a damaged window on our 83 Sun Lite Eagle but it's got the older aluminum siding. It would be nice to move away from butyl tape and sealant wherever possible.it didn’t come with template they give you dimensions and radius size for cut. The window sandwiches between camper shell with a gasket and screws
Are you planning to run corner trim around the edges?I sealed all the ply wood for the bulkhead and bed floor with resin . I caulked everything before and after installing the wood and will be cutting and mounting the aluminum sheet on Friday once my order for 3M vhb comes in.
Yes 1/8 thick for tree and rock protection.Are you planning to run corner trim around the edges?
I’m not sure but if you can get siding mostly flat I’m sure it would work.Ahh I see. Do you think the gasket would work with corrugated siding? We have a damaged window on our 83 Sun Lite Eagle but it's got the older aluminum siding. It would be nice to move away from butyl tape and sealant wherever possible.
Nice and beefy!Yes 1/8 thick for tree and rock protection.
Is that a drawing you did? It looks good!
I did not draw it. Credit goes to @The.overland.design on InstagramIs that a drawing you did? It looks good!
It don't matter,day,night,rain ,snow it looks allsom badass. No doubt about it.
thanks!It don't matter,day,night,rain ,snow it looks allsom badass. No doubt about it.
