Does your scan tool allow you to reset the fuel trims? Be interesting with the new maf how a reset would do.
Looks good to me, run it. Do a tail pipe sniff test with a load and call it a day.Not that I’m aware of however the shorts looked better after the MAF replacement. I think I need to get through a few more heat cycles to know for sure. I also noticed the rpm went from 700sh to 800sh.
This is why I think every hot rod should have a wide band o2
The drivers fender is original btw
Ideally, the LTFTs will be similar, but a difference of 5% is fine. When it's done learning, the STFTs will be at zero, no matter where the LTs settled in. Kind of the definition of STFT.see what the fuel trims are doing, they all should be within a couple of percentage points of each other.
I had the same thing happen on my c10, no scan tool or any parts changing would make it happen. The gas tank had water in it. Might be worth it to pull a fuel sample, or a peak inside the tank.
