Well they're on and they look pretty damn good.
Are you going to have the same problem as me getting it in/out of the garage with the 40s on?
Don't think it will fit in/out with the 40s aired up. I could squeeze in on 37's so I hope I can do it with the 40's aired down.
Thanks guys,
Remember I was saying that I needed to supervise Raji and his cousins when they installed these tires? Well I didn't (long story) and even worse I didn't notice this until I got home :doah:
Not too much other progress to report other than a reservoir bracket I made to hold the PS reservoir on the rad support. Spent most of the day yesterday helping a friend install FiTech on his ZZ502 BBC. Amazing how much the throttle response has improved with the EFI.
What is that throttle cable bracket you are using, @skunked? I'm thinking I dislike my single bolt bracket and would like to upgrade.
@skunked ha, i don't think they understand what rock rings are for, guess you should have supplied your own valve stems.
I have been first hand witness to unprotected valve stems causing a flat on the trail but the guy had a fullsize spare so it was a quick fix.
