Same, that really is disturbing. If I remember tomorrow I’ll take my laptop to work and compare those to a 5.3 6.0 and a duramax tune to see where it lands.Thank you everyone for the guidance and feedback.
I’m still a little shocked that Howell sent me two PCM’s with those TQ Management settings.
Nice work dude! I was starting to think you were going to have to carb swap it![]()
The 2001 file has a single row, but higher values: 326 at 0-400, up to 526 at 4k, everything above 5k is 447.
Also, does Howell have any explanation for your torque being limited to 350?
Keep in mind they've removed your low octane timing settings, such that it's technically setup for better than baseline gas. You can verify that it's real by temporarily upping the octane, but it probably is real, as it has a lot of timing. A little bit of knock retard sometimes is considered normal, but you're not even at WOT here, so it's definitely something to keep an eye on as possibly needing adjustment. It's hard to relate the kPa to airmass, but the table does have another 10 degrees to pull.well the TQ Management was part of the problem. She scoots now however the fuel was still rich and now I have some knock retard![]()
I do believe it is the same tune, they loaded the same into two different PCMs. Also suggests PCM 1 is probably goodThank you everyone for the guidance and feedback.
If you have those runs from yesterday in a data log, send them over to Todd so he can look at them on his computer rather than trying to look at them on here from the screenshot. Us old guys can’t see that shit.Couple things to note.
1) I made all the changes that @Tnsejed noted a page back to the torque management settings. Not just the 350 bump to 640.
2) @Blue85 you mentioned that you didn’t see knock retard but I see it noted in two places at 4.2 on the screenshot from last night. Maybe I’m looking at the wrong figure?
3) The engine wasn’t fully warmed up therefore I believe the richness figures may not be a fair comparison to other screenshots provided. It’s never mattered if it was hot or cold, it would still rollover albeit a bit worse when it’s warm.
4) I haven’t spoke with Howell about the torque management settings but I will. I wasted a bunch of cash fixing something they should have figured out by now. And I likely have more adjustments to go.
Is there a local tuner there that does LS work? Or even a remote tuner you’ve heard of. At this point I’d want a pro looking at it instead of guessing just to get my baseline right.
It is worth noting, most tuners do not like messing with the torque management stuff. And almost all cases, they might make some slight modifications to it, but they want to leave it in place. And there are a lot of good reasons to run it rather than completely delete it.Is there a local tuner there that does LS work? Or even a remote tuner you’ve heard of. At this point I’d want a pro looking at it instead of guessing just to get my baseline right.
I think there are some strong clues here, as the PCM is overcalculating the torque while running very rich, which implies it's calculating airflow too high.On a tech note I came back to add that the torque model can only be calculated correctly if the Air model for the engine is correct. We can have problems with that when using non OEM equipped displacements. So its not always a reliable calculation.
OK, it makes more sense knowing you already changed those tables.Couple things to note.
True but they can probably see something better than we can on the other side of a laptop and could identify some other gotchas. Like I said, just someone to baseline the tune and then adjust from there.It is worth noting, most tuners do not like messing with the torque management stuff. And almost all cases, they might make some slight modifications to it, but they want to leave it in place. And there are a lot of good reasons to run it rather than completely delete it.
