84 K20 "Ethel" Not an Sbc/NV4500/241C
Semi restoration of a 1984 K20 pickup. 5.3 LS, nv4500, np241c.
I guess you can't change the throw out bearing measurement since you already have the short one. Can the clutch height be changed using different parts? What was it like on your 6.2?
So will that work? Or is that too much for full release of the disc?
I never have had to get this detailed with a little clutch.
So it'll swing near 1.0 in total before the fork bottoms on the bellhousing, and releases about 1/2 or less and that's with my tcase in 4wd and the trans in 5th so with the engine load it'll disengage way before that even does. So I'm happy with this, it gives me some room for a taller TOB if I need it. Feels good to. On to fitting this biatch in the truck now!
:saweet:
So...
Are you done yet?
If y'all hadn't brought Jeep's into this we wouldn't be off track...
The thread was in the crapper a long time ago..
