That sounds reasonable..
My springs have 2 leafs.
I charged the batteries up, changed the oil and filter, put 7 qts of delo 15/40 back in.. It reads over full now... Thanks Internet.. But damn it's quieter when it's idling.
Checked the fuel filter and the leak I think is just the seals hardening on the filter itself so I'll replace that this week.. I need both radiator hoses, but first need to verify its not leaking water at the pump, it's coming from somewhere..
Reseated all the fuses and that gave me dash lights! But I still have no oil pressure reading and no glow plug light unless cranking hmm..
Alright I need some help detectives!
Ther is this hose coming off the injectior and is not plugged??
This yellow and black wire goes into the harness???
Here's the relay wiring.. Once I got the batteries re wired and cleaned up this is working as it should and the truck starts really easy now.
I have several leaks at the injectors, I haven't tried to tighten the connection between the line and injector yet, is there an o ring or something I should be replacing?
I did test the glow plugs and they all lit up with my test light while cycling.
I also discovered this green and blue connection that went under the truck and was cut off.. No idea but it does go into the cab where I was not able to trace it out due to no light.
