Yeah I have no idea either. The carter I googled said like 6-8 psi and 100 gph free flow. They work on dodge cummins turbo engines so should be ok I bet.
But my engine is 300cc bigger than a 6BT. Surely I need more fuel flow than they do!
Ah crap I didn't see that but the underside has the imprint from the egr.. I had him send me this because it had the boost nipple and the map sensor there.. and I honestly didn't know the egr version was different.12 psi is max lift pump pressure the db2 should see.
The upper intake looks like it's an egr version. Though the lower intake looks like a non-egr style. Will still work. Just a little mismatched.
http://www.facet-purolator.com/cube-fuel-pumps.php
Wow I forgot they had like 20 models. Is the outlet port on the tank switch a barbed fitting?
I have a version of their Gold Flo. It's worked well so far. A bit noisy, but effective.http://www.facet-purolator.com/cube-fuel-pumps.php
Going for blood test tomorrow morning, he said the vasvogal syncope could be a possibility but wants to check everything anyway. So I get blood testing and the heart doc stuff as well.....so what did the Doctor say....
For the lift pump should I put a regulator in line? The Facet pumps I thing are lower psi than 12
Is it a big deal? I can just cut the egr portion out right? I figured an air grinder would make short work and I can clean up casting flash and sand blast everything while I'm in there..
Say wha?Going for blood test tomorrow morning, he said the vasvogal syncope could be a possibility but wants to check everything anyway. So I get blood testing and the heart doc stuff as well..
They took 14 viles.. I am now referring to phlebotomist as vampires!Say wha?
When do the results come back?They took 14 viles.. I am now referring to phlebotomist as vampires!
A weekWhen do the results come back?
Your body might have even replaced those 14 vials by then.A week
