I have the
VHX model and they are absolutely amazing. Easy hookup and setup. Just cut the plug off the stock wire harness and put the wires where they are supposed to go. No problem with the LS tach signal being too weak, just be sure to run it in 4cyl mode. It will output a VSS to the ECM if you need it. All of the factory stuff is there, 4x4 indicator, seat belt light, check engine light. The oil pressure and temp sensors come with the metric bungs to plug into the LS. The two screens will cycle through a ton of things including all the gauges in case you want a digital readout. They can be programmed to turn of certain things so you don't have to cycle through 50 screens to find the one you want.
The only thing is, if I could do it all again I would get
this model instead. I like the retro gauge faces
