Really cool pics. Those wild horses are really neat, live in the heavily populated eastern half of the country it's hard to believe herds like that still exist.
Our wide open desert sure is a blessing I am thankful for.Really cool pics. Those wild horses are really neat, live in the heavily populated eastern half of the country it's hard to believe herds like that still exist.
Finally got version 2.0 of the parking brake cables built and working. A little tricky getting the camaro park brake lever to work with the aam brakes
It's not hard. I made a little bracket to make the cables work on mine. https://ck5.com/forums/threads/k5-parking-brake-cables-in-14-bolt.340907/#post-4101867
You can also swap the backing plates out to a different style to match up to whatever cable you have.
Is it a disc conversion from drums, or a late model aam with factory disc?Mines disc brakes.
Yeah ok, depending on what kit is on there now, you might be able to run eldorado calipers that have a built in brake but ymmv from what I’ve read.Im guessing it’s a disc conversion I can’t see anywhere to hook the parking brake. Guess I’ll need a driveline brake set up instead.
She’s a ten footer.Pretty clean
You got itFlexible funnel thing
How do you like it? I've been looking at them and if they work as advertised I have some solid uses for them.You got it
I love it! I think the one I have is the medium size.How do you like it? I've been looking at them and if they work as advertised I have some solid uses for them.
