If you aren't low on fluid, it does sound like the pump isn't performing.
Why change the accumulator? Is it not working?
I did test it and it doesn't work, as soon as the engine dies no power assist.If you aren't low on fluid, it does sound like the pump isn't performing.
Yeah looks like I am getting new everything, except I can't find the hydro boost new, only remanufactured.The only test I know of for the accumulator would be to run the engine then shut it off and press the brake pedal and see if it still has power assist from the accumulator for a few pedal presses. I have never done just an accumulator, I have only done the entire hydroboost booster.
Yeah I don't like using atf but it had atf.It does sound like the pump is weak aside from the hydro boost issue.
I converter my 67 f250 to power steering and hydro boost. I used the Thompson pump for a Ford fe engine.
It would not allow me to turn and brake assisted at same time. I had to get a special Saginaw pump, this pump was able to work both at same time.
I have changed @ 80-100 hydro boosts, not once have I ever had an issue bleeding the hydraulics.
I always use power steering fluid on Hydra boost. I know old school was atf, but I think atf is to heavy for Hydra boost.
Good to see it's back together, to bad your wife does not care for it.
I had to get 2 rebuilt hydro boosters from Summit, the first one started leaking a week after I put it in.I'd just do the reman from Napa. Kinda a crapshoot wether you will have problems with it or not but for the most part I've had good luck with Napa reman stuff.
I decided to drive it a couple of days around town, and most likely I would change the pump next week. I noticed when I hit the brakes whether moving or stopped I feel very subtle pulsating, I wonder if that's a sign of the pump not getting enough pressure or the booster failing?Are you particularly determined to have a working accumulator?
If I were in that situation, I wouldn't rip out a good working hydrobooster and replace it with a parts-store rebuild. That's a crap-shoot, trading a known good unit for an unknown unit, just for a feature that hardly ever gets used.
I drove a whole lot of miles without ever realizing mine was broken. Losing brake boost isn't a huge issue in my book. It's not like the brakes stop working. Losing power steering is more annoying than losing power brakes.
To each his own...
The way I have very little requirements for driving a vehicle but my intention is to make driveable by anyone including a prospective buyer. I don't want to replace everything with new but I do want to have everything functioning.Are you particularly determined to have a working accumulator?
To each his own...
I know that.... But an accumulator should only affect the system during that brief moment after the engine stops.
Is there anything out there that is worth the extra money or do I just get the remanufactured one from napa for $125?
Yeah I don't need wilwood, stock replacement new for $150 I think I will get itIt's pricey but Wilwood makes a setup.
