84 turbo diesel suburban
imiceman44
Hoarder extraordinaire
Lincoln, CA
imiceman44 submitted a new Build:
So I have had this suburban for many years, I want to say 15 years.
Bought it not running, supposedly bad ip, tried to mess with the timing see if it wanted to start, changed glow plugs, checked compression and it was ok, even in all cylinders, then someone from upstate new York bought it sight unseen and was sure he could get it started and drive it home from California.
He flew in with his wife spent all day, could not get anywhere, so I offered to take it back.
A few years later I traded it for a diesel crew cab project that supposedly ran, after a few months of trying to get it it to run, he gave up, and I traded him a turbo setup and a front d44 8lug 4.10 gears for it and got it back.
It sat at my buddy's house for the past 7years and now I have an engine to swap in it.
I got the engine from Colby Stephens truck that I parted recently. The engine ran pretty good before I parked it and eventually pulled it off and it sat for a few months outside.
Read more about this build here...
Today we continued to disconnect everything, and started pulling the engine when we realized we forgot to unhook the throttle cable and the tv cable.
I think the throttle cable is fine, the tv cable I am not taking chances so I want a new one.
Then we started to get the turbo off to put on the other engine, and we saw we need to get the valve cover on the passenger side moved because it already has a hole for oil return for the turbo.
We pulled the valve cover and found rust on the rockers and valve train.
I guess years of sitting moisture got in.
I pulled the valve cover on the other engine and it's super clean .
When I pulled the turbo exhaust manifold and the other side, there was no gasket.
I remember a discussion about that not long ago, I guess if the surface is clean and straight enough it's fine?
Or should I put gaskets.
I downloaded a factory service manual.
It says to use RTV on the valve covers.
I've torn apart several over the years all had RTV on the valve covers
Both engines had rtv on the valve cover.
The exhaust manifold though only the engine Colby built had them, the turbo didn't.
Colby used the cork gasket slathered with blue silicone on the valve cover.
The other had goops of orange silicone that squished all over.
Orange silicone the same stuff I have seen on what seem to be stock 6.2s though all the 6.5s had gaskets
Yeah
I might do like Colby.
I like that it didn't look like he used silicone and it was sealed good.
I have work for a couple of days then I will be back on it.
Hopefully it will be running by the end of the week.
I am thinking about putting a 1" body lift on to help with clearance to the engine and trans.
It will also help with the 33" tires I am thinking about putting on.
I already had 33" on the other suburban and it only rubbed a little when I wheeled it.
Use The Right Stuff for everything. https://www.amazon.com/Permatex-99070-Right-Stuff-Gasket/dp/B000HBM6PE Not cheap but it never will leak and sets up in a little while. I get this kit at my local parts store but it's probably more than on Amazon. You can also get it in a regular large caulk tube but then you risk it drying up before you use it all. I like the half size tubes. Ford 7.3L oil pans use only silicone and you put it on close to 3/4" thick on the ends and 1/2" thick on the sides and never an issue with this stuff.
If the manifolds are pretty flat you could try to just using high temp rtv on them. I always like gaskets. Powerstrokes come with no gaskets from the factory but then when you take one apart the first time you always install a thin metal gasket.
So today my helper didn't come and I had a few things going so I only got a few hours in, and the fact that it is 1 hour away from home doesn't help.
First I clocked the alternator so that the braket ligns up properly.
Then I transferred the tv cable bracket and all the automatic transmission stuff as well as the cruise control.
This engine was mated to a sm465 and in a stripped down truck no a/c.
I also got the engine degreased somewhat.
I am not trying to win a trophy or even paint it.
I just want to put it together without getting too greasy and be able to see leaks as they develop.
I also too off clutch and flywheel and got the flex plate.
So the original engine has dual v belt pulleys for the power steering pump.
The one I have has them on the crank and water pump but not the power steering pump.
I see a alen wrench hole, is that to hold the shaft and unscrew the pulley?
Or is it pressed on?
I would use that pump if the bracket was not cracked.
I also would like to replace the square fuel filter with this spin on filter.
What do you guys think?
And these are some close up pictures of the modified intake.
Last one is the stock one with the provision for mounting the second filter
@campfire
For what it’s worth, I’m in midst of doing a Banks Sidewinder on my j code 6.2. They say not to install a gasket on the exhaust manifolds. Don’t know why that is but I don’t know why it would hurt.
I plan on doing the spin on filter as well. I want to put a ball valve on the outlet side for bleeding it.
GM didn't use exhaust manifold gaskets on their engines factory,they just planed the manifolds flat and put them on without any--you can buy aftermarket gaskets ,but they usually burn thru in short order and make that annoying lifter tick sound..
I just clean the manifolds good with a block of wood and sandpaper,and check to see if they are warped,if they are its best to get them planed flat and use no gaskets..
Every 6.2 I've seen apart or in a vehicle has that orange RTV oozing out of the valve covers--might be what GM used factory ?..no gaskets used factory far as I know,though you can buy them if you prefer using one..with the valve covers being a major teardown to remove,I'd want to never have to remove them again.
The P/S pump with the cracked bracket couldn't be welded up ?..be easier than swapping the pulleys,you need the special puller to get them off (can get one at Autozone "free" after leaving a deposit)..
I seem to muck up P/S pulleys every time I went to take one off,some are a real tight press fit..
If you see yourself doing more power steering pumps in the future I highly recommend the snap-on puller and installer. I cussed some cheaper parts store ones before and having the new one makes the job a breeze. Sure it’s expensive but it was worth it to me
I have the pulley puller installer tool.
I did change the pulley it was easy.
I was cleaning the exhaust manifold and was thinking not to use the gasket and then I saw someone had banged on the surface and put dents in it.
I decided to use the gasket to make a better seal.
No sanding was going fill those dings.
