'85 K20 "Whitey"
Nothing much to report here for progress on Whitey. I have some stock blocks off a '08 Sierra I'm going to stick under the 4" rear blocks of the truck. They're roughly a inch and a half. With the junk out of the back these blocks should level the truck with 4 tires that have matching tread.
I don't want to use an add a leaf, because it doesn't need to ride any rougher than it does. I'll prob do a shackle flip like Chris's truck later on.
I haven't installed them yet. They're a dowled block so I honestly don't see what could be so bad. The u bolts would have them sinched together no different than the leafs and blocks it has now.
It would be the leafs, a 1.5", and a 4" block with heavy duty u bolts. If something shears the u bolts I'm in trouble no matter 1 or 2 blocks.
Meh. I hate blocks. Zero rates are okay by themselves. I know thats not what you wanted to hear.
But if it doesnt get captured with the center pin bolt going through it, I wont run it
