Got a few onesie-twosie little things done over the past few days.
Put the intake manifold back on, but clearance to the firewall was very tight. Then realized there's a plastic cover of some type (I assume for noise?) on the back side of the manifold that seems very optional. Took that off and now there's about an inch of clearance to the firewall at the closest spots. I also put back on some little stuff like the starter and alternator (just to have them in place to check clearances when I do the suspension).
I also put on the Summit AC compressor bracket, which fits a Sanden 508 style compressor and relocates it to the top passenger from the bottom passenger side. I don't have the compressor yet, but I will probably get it in the coming weeks before starting the suspension.
I was also having to keep at least enough air in the tires (which leak bad) for them hold their shape, because the transmission was sitting on a jack stand. So to make a slightly more permanent, but still temporary, solution I tried to see if I could get the factory W style crossmember in, even just partially, to support the transmission at least enough to be trailer-worthy.
It turns out a 6L80 almost literally bolts into a Squarebody, or at least an '80s Blazer I guess. With the engine in the stock location (via the ORD motor mounts), the transmission crossmember bolted into the original frame holes, and the transmission mount from the Yukon (which fits directly onto the crossmember without modification to either), the bolts that attach the transmission mount to the transmission are off by maybe a quarter inch (transmission sits too far back slightly). If someone was so inclined, I'm pretty sure you could make it work by just elongating the bolt holes in the transmission mount slightly. I'm not going to bother because I don't think I can use this transmission crossmember anyways (I think the ORD link brackets will be in the way).
To prep for the front suspension work, I still need to do all the front frame plates (including steering box plate) and install some easy stuff (brake booster, steering column/shaft) for clearance reasons. Hoping I will be able to start suspension stuff in January (I will have limited garage time in December).
