I agree about the prove type senders. I've been thinking about an online adapter like you're going. I think you'll have to ground it.
Did that. Didn't think to grab a picture. All I did was strip about 1 1/2" of wire and then tinned it with solder. Added a second hose clamp behind the primary hose clamp and slipped the wire underneath the hose and secured it with the hose clamp. I had thought about tigging on a chunk of aluminum and drilling/tapping for a small screw but this should work pretty well and very simple.
We built a mount for the winch solenoid box today. I had intended on welding it to the spreader bars of the winch itself. Well, they're aluminum and my sheetmetal mount.... I can weld pretty good but that just aint happening. I really thought they were a chromed steel. So, we made new spreader bars and then welded it up. Got some paint on it and its back on the winch now. Tomorrow evening i'll get the solenoid box mounted to the bracket and get the wires hooked up. Gotta find a diagram.
Then we decided we should get the last of the torque converter bolts in. 3 were in and three were not. This is a left over job from swapping in the 6BT and turbo 400 in place of the 4BT and turbe 350. I nuked a 9/16" ratcheting wrench tightening those bolts.
Got the trans shift cable hooked up and the sending units screwed into the pan. Trans is pretty much buttoned up now. Found a stripped out pan bolt hole. I think I can get a 1/4" bolt and nut on top to make the squeeze. It's near the tailhousing so not alot of room on top but maybe just enough for a 1/4" nut.
Then we took a look at the power steering pump situation. The plan has always been to add a larger resevoir to the steering hydraulics. Problem is the pump that's on there has the breathable cap. We really wanted the res. up higher so that cap was not gona work. Thought about doing the radiator hose trick but that's a no go. This pump has the oval shaped neck. We ended up, cutting off the return line, crimping it shut and tigging the end of the tube for a seal. We used one of our steel 3/8" NPT bungs and tigged it over the fill hole, fit perfectly. Now we can plumb it directly to the resevoir and have the res up higher by the brake booster.
The list is as follows
Install solenoid box and wire the winch
Steering column support bearing
Starter button wiring
Battery cable junction
Switch panel B wiring
Wire all sending units
Wiper motor electrical connections
Rock light install and wiring
Rear facing lights???
Front "Low beams" and turn signals
Rear Stop, tail and turn including markers
Wire up monitor and cameras
CB radio mount and wiring
Electric fan wiring
Tool box light
Grid heater wiring
Fuel tank vent hose
Fuel shut off
Hand throttle
One front suspension bolt that is causing me grief
Tube doors
turbo intercooler
hood
