63chevyll
Finally able to work a deal on this suburban.
Been looking for over a year and came up with this. This is good cause Ill be able to get rid of 3parts trucks to support this cause
The blazers just don't fit my family anymore.
UPDATE 9/7/13
1985 suburban
TBI 454 (converted from 350)
TH400
Gear vendor GONE
D60
FF14B
4.56s with Detroit or tru trac in rear (need to verify)
Redneck 2wd steering box, ported w/ crossover steering, BONES steering arm.
Frame repair done behind box
Engine and Front crossmember built and in
Front 56's springs with 7.25 shackles
rear 63's with 7in shackles
The good:
It's mine
Wife is happy
Fits all kids (3bench seats)
Running gear is solid
Its Bdass to me
The bad:
Needs some maintenance work, but all able to do as I go and keep it driveable.
Oil cooler lines leaking, FIXED
Has power Windows
The ugly:
King pins real loose, FIXED 11/19
Has a tape player removed
The plans:
Lift 4 inches, front done and back
Install new tires, done
Remove gear vendor, removed
Bust out cut off wheel for rust, soon
Longer drive shafts. Done
203 205 ORD doubler and the right TH 400 that needs to be installed, don
Winch bumper and add winch 16.5 TI done
Engine mount cradle DONE
Remove front crossmember under radiator is build something more supportive DONE
build shock hoops done
Fix little stuff as we go
Keep wife and kids happy
Will update this thread as I go.
Pretty excited, never did a build before on anything with 4wheels and I will gladly accept any suggestions or criticism as I go. That comes with the territory from internet.
Thanks for looking
Brad
Pic
UPDATE 9/7/13
1985 suburban
TH400
Gear vendor GONE
D60
FF14B
The good:
It's mine
Wife is happy
Its Bdass to me
The bad:
Has power Windows
The ugly:
The plans:
Thanks for looking
Brad
Pic
