'86 Jimmy 4in Lift, 40’s, tons, 8.1 Swap- 700r4 said PNNNNN
This is not a dedicated trail rig, but does trailer to the destination usually. I am currently in the planning phase of doing a 52/56" spring swap, and getting back to being more road worthy.
Spent a few hours in the garage this morning.
Stuff completed:
  • Plugs and wires (anti-seized the plugs)
  • Exhaust manifolds and gaskets (missing a couple bolts)
  • Final intake bolt down (still need to run the torque sequence)
  • Heater hoses
  • Radiator with shroud and fan (had to relocate a hydraulic line for the steering)
Stuff to be done for engine to be ready to fire up:
  • Plug oil level sensor hole
  • Plug cooling line holes
  • Remove oil baffle (right name?) from filter adapter
  • Radiator hoses and crossover hose (water pump to crossover pipe)
  • Hook up fuel line to injector rail
  • Block off/plug any unused sensor holes
There’s things I’m sure I forgot, but this is plenty to keep me going for the next round of work.
Stuff completed:
  • Heater hoses
Sweet! Good works, man. :saweet:
Thanks DudemanguyEthan!!!
Went ahead and picked up this small hose. Don’t let the size fool you. That was a massive pain to install. :angry1:
Also went ahead bought a new AGM battery since the last one was forgot in the crusty Cheeto :doah:
So in terms of the tune, these are things I need to delete:
  • Vehicle anti-theft
  • Evap
  • Rear O2 sensors
  • Torque management
  • Burst knock retard
Anything else I am missing?
