I looked up a schematic for an '01 and for an '06. Older one had 9 wires to the pedal and newer one was 6 wires. TAC module is different. I can try to attach both schematics if you need them.
Good. What year did Howell set up your harness for?I have a buddy at LKQ pulling me a pedal and module from the same 2006 2500HD truck in their yard. We’ll see what happens.
2002-07Good. What year did Howell set up your harness for?
It’s got a ton of throttle codes. I just don’t know if I trust the legitimacy since I can’t guarantee I have the right module and pedal.If I still had access to the GM parts catalog I would be able to check the numbers of all three versions, Diesel, 8.1 and LS to check compatibility or not. Trying to find it on GMparts direct is an effort in futility. I don't remember if there was a difference or not.
What I do remember is if there was a problem with the TAC module or pedal assembly it would set codes in the ECM. Have you checked if it's setting any codes? On the off chance no codes are setting I'd question if the programming was set up for the DBW system or Cable.
Nv4500’s don’t barf fluid or have cables that keep them from shifting…. Just saying.Lines temporarily fixed. Oil dry down. Took almost an entire 40lb bag.
Unfortunately my B&M shifter cable is seized solid. It’s seized in the neutral position, so the movement last night was just gravity. New cable should be here tomorrow along with the factory trans cooler lines.
