Good idea!
I do believe it’s an optical illusion. The hose exit is further forward than that port, but I’ll grab a better picture.Are you referring to the plug which is sort of under where the upper hose runs?
That one is 1/2" pipe, so you need a bushing. That can push the sender up and make the electrical connector hit the radiator hose. Can I suggest that you mock it up before you install the intake??
Then if you don't like how it works, you can tap the port without worrying about shavings in the coolant system.
That’s kind of what we mimicked, but made the inside diameter larger to fit over the 14 bolt hub, yet small enough to mount a Wheel over.That spacer you stole off of you brothers truck looks like a factory Dodge piece
Yeah, I glanced at it this morning. You're right.I know that the hose runs forward of that, I have the same intake. I am just saying that it isn't a great fit there. I drilled mine.
Nice!
Should be 3/8" pipe thread.Nice!
And yeah, I always like pics...
So what size are those sensor threads?
Yeah no crap.Should be 3/8" pipe thread.
I was lucky to borrow a tap from work. Don't need that size much.
Yeah no crap.
So with a 3/8 thread, it uses a smaller bit correct?
As you can see, I don’t drill and taps much.
@campfire that's a good explanation!
And I am not surprised that you know where to find info like that.![]()
So spend a little more money at Lowe’s or Home Depo and get a quality set.
