beags86
Eastbound and Down
Where is this starter from? Junkyard or ??
You probably should just have nice new shiney unit on there anyway.
It was the starter that came with my engine accessories. I just picked up a new unit. Headed back home.Where is this starter from? Junkyard or ??
Ok, on to the next issue. No spark now.
Looks good to me too, but that ain't telling us if it's generating a signal for the ECM. So we are back to trying to see if we have a signal. We could loose the cam sensor signal off the front of the engine and it will still run. It takes a few more revolutions to go around for the ECM to reference where #1 is off of the crank signal alone, but it will still start. But since it's not starting or popping at all it's not got any spark. If you don't have any type of scan tool to plug in and get a reading on the crank signal take a tach and hook it up. Your harness should have a circuit marked for the tach signal coming off of the ECM that you haven't hooked up yet. You typically need to switch the tach to 4cyl mode to be accurate, but in this case it don't matter. You just want to see the tach needle move while cranking. IF it does we can rule out the crank sensor and or wiring to the crank sensor. If the tach don't move then we have a few checks to make on the circuit itself which aren't too hard other than accessing the plug at the crank sensor.
I'm hoping you put a new crank sensor in prior to install because it's impossible to change in the truck.
Sorry, I have to point out that this is false. Cause when I was having issues with my first 8.1 when I was doing my swap, I was able to change the crank sensor while the motor was in the truck. Only part that was a little hard was getting the little bolt that holds the sensor in place loose/tight, other than that, not that big of deal to replace the sensor.
Just thought this was worth pointing out
Mine looks easily accessible from under the truck as you can see in that picture. But I’ll know more today when my buddy gets here with his laptop.
I did find an old tach I had sitting around, so I’ll hook that up after I remove the obd port and see if I’m even getting tach signal.
