Finished off the passenger side of the box. Hit the whole side with the DA as the primer that was there was showing some rust and was getting oxidized. Looks like a big slab of Bondo, and it's thicker than I'd like at the front edge. Had a bunch of small dents and crease's there. It's good enough for what I want out of it.
Did the drivers side too. Will need to give this side a little more attention. The surface rust was worse. Need to dig out the fuel door too.
Started working on getting the drivers taillight to fit better. I got it decent by cutting and folding back the metal in the light bucket. Guess I forgot to take an after picture.
Unhooked my wiring and undid the box bolts to start lifting. Can also see the extra tank I put in, not sure if I covered that or not. The rear is the primary tank and the side dumps into that with a TBI pump on a separate switch. Have a rocker switch that toggles between the tanks to show fuel level on the gauge.
On to some sawhorses to finish off the body work. Did get some primer so I can shoot that when ready.
