gmcjimmy88 said:
To start with I want to say that looks awesome, you do some great work. I have made it most of the way through this thread and I may have missed this question being asked but here it goes:
Q......Have you thought about heat build up in that box? I would not think it would get to hot but with it being water tight it should be air tight as well. With as many relays, solenoids, and etc. in that space and no air flow/movement do you think it may heat up? That could be you extra guage? A temp guage for your wiring box? Not sure how you could get airflow and keep it water tight though. Just my thoughts, I will read on now and most likely see the answer to my question.
Your work is Killer! Had to say it again.
hey thanks man, means alot...
Thats an interesting question you raise...
My thought is, no, heat wont be an issue.. Here's my train of thought... First personal experience, I see tons of electronic setups in boats that are watertight, confined, etc and it's rarely an issue for them... And alot of those have components that will actually heat up to some extent... As a matter of fact, today I was working on an enclosed system under plexi with a couple big slaves and a nasty series/parellel solenoid...
Nothing I have in the box at the moment really puts much out... I can't see relays really putting heat out of any significance, the slave solenoid and ACR might put a minor amount out when in a "closed" position, but they are not continuous and are only that way for moments on occasion...
The only item in the box that may be an issue is the welding rig... It's really just the control box. doesn't look like it needs ventilation from the pics, but thats pretty far down the road... I'm more concerned with having room for it...
I know it has been brought up about condensation being a possible concern, and I'm sure a certain % of moisture will be in there.. But I thought it might be a good idea to take a few of those pouches they put in with electronics for moisture and just tuck them in the corner to combat that... But even that, I think is pretty overkill... Considering what "standard" installs go thru weather/corrosion wise...
Thanks for the question... Discussing tech stuff is so fun...
Anyone have any questions, criticisms, etc, feel free...
Btw, body tech for those that didn't already know... zinc chromate on the bare stuff, then the tan epoxy primer.... hopefully paint pics sunday!!
