ok, hope noones on dial up...
some of the recent progress.... the rest of the frame in all it's naked rawness...
in zinc......
beginning the sliders... tape cutline on the rocker.. I left a 1" tab lower on the qrter, so it can be bent under for a flange to the slider...
the final length of the slider...
the line for the sectioning of the wheelwell..
one of the pieces removed..
welded up, moved the opening about 4" forward... by sectioning it, I'm able to keep the 1/2" raised lip bodyline around the qrter...
the slider will have a matching angle cut...
it also gives me the inner lip flange... still need to do a little patchwork at the bottom before I final mount the sliders...
I'll finish that up once I fit the custom cab supports in... you can see some rough sketching of future fitment...
the x-member will be the same 2 x 4 as the sliders, with a 1 1/2" x 3" spacer pad at the end to mount the slider to..
kinda hard to explain, more pics coming...
