sure, I'll take some.. the only section of that that are missing at this point, are the very corners where the tube is....
BUT I will be chopping out most, if not all, a whole big window right behind the window for the plexi in the dashpad/cover to the right... there is some room between the 2 for the plexi holding frame, leds, etc... but I'm thinking it'll be vastly easier to work on/install/change inserts, with a giant window in that substructure too..
on looking at it yesterday tho, I'm not 100% on doing a full window unsupported... cuz that would fully separate the top of that structure, where the windshield area clips for the pad/cover slide in, and the bottom of the dash, where the front lower screws above the glovebox would be are..
it would still be attached over in the middle of the dash.. but the whole section to the right of that would be split... but, it may be fine without doing any bracing at all, I'll see... i'm actually running a full 2' of 2" x 1/4" steel along the lower glovebox door hinge line for the new hinge/kick panel gig.. so that beef may help too..
I have to see how flimsy it makes the whole thing, if that would also want/need/have to have structure support added to it, yada, might as well, blah, shoot me now, etc...
also, the plexi frame is gonna be a bit more challenging due to curves, tightness, etc... but I don't wanna cut out the dash for that till next weekend when I have the plexi "in hand" and I can verify EXACTLY where the metal edges of the dash around the plexi need to be.. than I can frame it from there...
