MIKESMONZA
Registered Member
After being away,for any Lenghth of time and being cautious;from past experiances,
Some with Relatives and Critters,
example,Birds, Squirels,rats.mice and rattlers looking for them!!!
I live in a Rural East Texas,go figure!
I always check all of the under hood stuff,
H2O/Coolant Radiator/Tanks,Oil, Brake Fluid,,Transmission Oil level's Battery conection's ,clamp's/Cable's,
Belts and Hose condition's
then while cold,, 40-45 degrees,,no wind chil,!l
I went to check my Oil Dip Stick,,, and it would not budge,
It has never gave me A problemn in the past
,I slightly twisted it and wiggled still it would not buge more than a 1/4 inch,,
I tried starting Motor and Letting it Warm Up,,
and tried again,,, then put a Screw Driver Handle to pull it out,,,,,
then the Gray (7/ 8th circle) handle came off in My hand !!!
Now I am trying a Pair of Locking Vice Grips on the part that is left,
Still no movement ,
I would next try a small Dent remover tool hooked to the Pliers,
Should I try some Oil?
or has someone also had a simular problemn?
or fix ,,,,,,just short of RnR ,,,the Whole tube assembly?
I also need a measurement,,,,, tip to stop,,, on stick to repair or find a simular stick with same measurement's????
also There is no noise coming from running motor while,Twisting and Pulling!
Mike
Still no movement ,
I also need a measurement,,,,, tip to stop,,, on stick to repair or find a simular stick with same measurement's????also There is no noise coming from running motor while,Twisting and Pulling!
Mike
I.E. Bumping the Starter, with out Helper,
