Scrt_Agent_Man
Registered Member
I bought this 87 Blazer to build for off roading so I could keep my 89 as my daily driver but I moved and with the HOA I don't have a place to work on it. This was a project the previous owner couldn't afford to finish. The motor was swapped prior to me purchasing it and they couldn't get it running again. The problem was a bad fuel pump and clogged lines which have all been replaced and it's run flawless since. I've put about 5,000 miles on it since I got it. This vehicle is a project therefore it does need some work but it is drivable. I will continue to try to work on this until it's gone. This vehicle also has ALOT of extra parts, bolts, ect that will go with it.
The Good
*1987 Fullsize 4x4 Blazer Silverado (145,XXX Actual original miles) CLEAN TITLE
*Fuel Injected 350 (5.7) (Approx 48,000 miles)
*Automatic 700r4 with stock Transfer Case
*No Leaks
*Has aftermarket 3.73 gears front and rear (can't remember brand) and manual Warn Superwinch locking hubs
*Power windows and locks
*Cruise Control
*New 1989-1991 Front fenders (inner and outer), core support, grill, headlight trim pieces (Grill, headlights and trim pieces aren't installed yet and it still needs front blinkers) (Also have original core support, headlights, etc)
*Chrome 15" rims with 33" tires (80%+)
*Hitch and rear tire carrier
*Put in NEW spark plugs, spark plug wires, cap & rotor, fuel pump, fuel lines, fuel filter, air filter, starter, brakes (pads, shoes, and rotors), radiator, radiator cap, aluminum tranny cooler, locking gas cap about 2000 miles ago
What it needs
*The upper dash pad is cracked and weathered
*Fabric on passanger seat is tore up but the foam is in great shape (nothing some seat covers won't fix)
*Front end is not painted to match and front side markers are shaved (welded and marglassed) but need to be finished)
*AC works but needs to be recharged as the condensor was removed during motor swap (system was kept closed up so it wasn't contaminated)
Pics can be seen here. The interior is put back together now though. http://s164.photobucket.com/albums/u18/Scrt_Agent_Man/87 Blazer/
Asking $3000 OBO
Email me at [email protected] since I haven't been getting on here much lately
The Good
*No Leaks
*Cruise Control
What it needs
Asking $3000 OBO
