If I had them I would use them.
The older ones as you stated don't have them so you probably will be fine but I like the added pressure spreading of these pieces.
Oh I had every intention of using them. I stepped over them on the way out of the shop after finishing the torque series for the oil pan. Just plum forgot them. Getting it on there alone was a real pain (even with snap ups) which is why I don't want to undo all the work I did. If it leaks, well then I'll redo it.If I had them I would use them.
If you used the new bolts that come with the gasket, they probably aren’t long enough for those spreaders.Oh I had every intention of using them. I stepped over them on the way out of the shop after finishing the torque series for the oil pan. Just plum forgot them. Getting it on there alone was a real pain (even with snap ups) which is why I don't want to undo all the work I did. If it leaks, well then I'll redo it.
If I use the oven I'm thinking 200ish degrees or something around standard operating temperature, a temp that the balancer will see when in use. I found a lot of examples of people doing this (Camaro and Mustang forums specifically). It gets that hot in the engine bay during a normal heat cycle or close to it. All those steel parts are heat sinks and get even hotter once you shut the engine down and coolant and air quit flowing.I wouldn’t put one in an oven. Might damage the rubber damper. I’ve hit cranks with a can of keyboard duster and that’s shrunk them enough to make things fit.
Great to hear you have it running again!Motor's running the best it's ran since I've owned it. Still hesitates every now and then at first startup. I'm sure there's another sensor I need to replace. I haven't ran it through a true heat cycle but it does not leak currently (knock on wood). Full tune up and I cleaned all the pulleys that were doused in oil and grease and I replaced the power steering belt. Found some interesting things when I changed the spark plugs you'll see in the photo below. Those three prong plugs were in cylinders four and six. All the plugs were bad carbon fouled from running rich most likely. I'm wondering if changing the MAP sensor might be the next one on the list. I jacked it up and put the back axle on stands and threw it in drive today as well. A very audible rhythmic clicking/clunking sound coming from the tail housing end of the transfer case. Gears seem to be very quiet which is a plus. I wonder if that bearing needs some more ATF. It's a little low in the transfer case where I've had the drive shaft out a few times and it's leaked. It also leaks anyways. I'm gonna top it off and listen some more tomorrow but for all practical purposes, I'm about done for the summer other than waiting on new driveshafts.
I'd have to TIG it though since the 208 is cast aluminum right? Regrettably, I haven't learned how to TIG.My t-case had a chip in that exact spot that the PO tried to weld up. It leaked. Not much. About a drop after driving. You could try that.
You know, this gives me a real good reason to go the SYE route. If the drive shafts weren't arriving Monday I would do it, but I don't want to have to wait another month and a half to drive it. You may have noticed that I posted in the parts wanted forum about looking for a NP241. My NP208 is leaking from pretty much every location that they can leak from so I'm going to have to pull it eventually anyways.Correct. And that is where the seal rests so it’s gotta be flat and smooth on the inside otherwise it’ll leak like mine.
A better way in this case is jb weldCorrect. And that is where the seal rests so it’s gotta be flat and smooth on the inside otherwise it’ll leak like mine.
