89-ish K5 build. Beat cancer!!! Time for icecream!
3 Link front, leafs in the rear, 2.5" ADS Racing Shocks!
On the rear ones do you think the frame flange will need to be boxed to the upper flange to prevent it from bending(if you were to keep them that way permanently)? I Have a really similar rear setup as far as shock placement goes and I need to fab some bumpstop mounts, I have some 4 1/2" poly bumps though. My axle is moved back some with my 64" springs but still pretty close to yours.
Yah I'll probably make some gussets eventually
Brake lines done in the front.. just need to do the rear tomorrow.
Decided against spending money on a fancy drive shaft. Going to strap it at 10" of travel using TSC axle straps. Spending 20 bucks sounds better than 80 for other straps. Still working on exhaust which I hope to mostly finish tonight as long as the kids stay asleep for me. Coming up on crunch time.
