'89 R3500 Crew Cab 2wd to 4wd conversion & beyond
Started out with 2wd TBI350 with SM465 to current 4wd with 454, 700r4, NP241
I thought if looked like the hydromat is some sort of threaded fitting.
But where does he get that capacity in a square tank? It's not a band aid. Everything I have read about it says it works. It has an AN fitting on it. You roll it up to install it. Talked to another guy this evening, in our club, who was having a problem with saddle tanks in the mountains, this fixed it.
Because one blazer tank is 31 gal, or opt for a 40 gallon burb tank.
One pump, no switch, centered baffle
No way I'm buying 2 hydramats at that price.
I don't think a 40 gallon burb tank will clear the rear axle. At least not without redoing the hitch and rear bumper.
Some quick math looks really tight
Maybe Wade can pull some measurements off his Jimmy tank
