Well, I'm still having the engine squeaking noise. I pulled all the rockers off, pulled the studs, cleaned the threads, re-installed with blue loctite, torqued to 52ft-lbs (recommended 50-55), and reset the valve lash using EOIC and 1/2 turn past no play.
I ran the engine and the squeaking started again after idling for a short while. I turned off and restarted to get a video. A short way into the video, you'd see me walk over and pick up the camera. Just before that you will hear the squeak come in just a little bit. After I pick the camera up, I blip the throttle a bit and then you'll hear the squeak come in earnest.
This is the noise we were getting before I re-torqued the rocker studs. In this video were were rolling the engine over with a ratchet.
I can still get that same noise now. It seems to come from both sides of the engine. Last weekend I had pulled a valve cover off and using a stethoscope, narrowed the noise down to the rocker. We were also able to pin it to (2) specific rockers on that side; #4 exhaust and #6 intake. We did see a loose stud, but when I reset them all, the rest all seemed fine. Nothing jumped out at me as being an issue when I took all of the rocker arms and studs off. I even looked to see if any of the valve stem seals had popped off or something. The ends I could see of the pushrods looked good, but I didn't pull them to check both ends.
At this point I seems like it's either got to be a bad lifter(s) or somehow a sticking valve(s).
The only other thing would be bad roller tips on some of the rockers. I rolled a couple of them in my fingers. The rollers would move side to side some and I could feel a little "bumpiness" when they rolled, but I figure they normally only pivot in place and not roll all the way around and I don't have a frame of reference for how they should feel. I just don't know if they move enough to squeak like that.
Things that are new:
- Cam
- Rocker studs
- Rocker arms
- Valve springs, retainers, and keepers
- Valve seals
I did cheap out and not replace the lifters. Also didn't do anything with the valves themselves for that matter.
