If you did hinges you would not have this problem on the rear ones, just sayin ....
I looked at one for ReTonkulous. Same one he has.that's great better than the one I have in mine which seems to be a power pig. Do have any idea of the amperage that one uses.
Congrats on the drip repairs always a good feeling
The bags I bring wheeling would work for that. They are just cooler bags . They do really well at keeping stuff cold / frozen most of the day wheeling.I'll look into this. Maybe I will be able to buy frozen at Costco again, since nearest one is 2.5 hour drive home.
How did you tie it down ?I wanted to mention this little fridge/freezer we picked up for the Rubicon last year. I was using it again this past weekend and I'm still impressed with it.
It was less than $300 and it will cool down below 0°. It ran great through the Rubicon and 5 days on the trail in 100° heat on our Utah trip this year. This rides in the non-A/C cab in the middle of the back seat of the crew cab. I haven't demanded much from the 0° range, but it's worked great for the 40° range.
My only complaint is the tie down options. We had to make our own strap setup for it.
Yeah that's like my reefer trailer it has continuous mode which is running non stop keeping the temperature at the set temperature +or -1 degree.We've run the fridge overnight in Eco mode in a couple of different vehicles without issue. One of the things I saw in the reviews that people freak out about is the temperature variation. It does that to conserve power. So if you set it for 40°, it will let the temperature drift up before cooling it back down. I usually set it a couple degrees lower if I'm concerned about it. The difference between Max and Eco is how much temperature drift there is.
I wouldn't rely on the fridge to freeze something but it will keep it frozen.
Yes, goldens are amazing.
I've been trying to convince Nicole that we need 2.Yes, goldens are amazing.
You know she needs a friend right?I've been trying to convince Nicole that we need 2.
