Very nice, does that eagle have dimples?
Just sayin
When he smiles, which isn't very often...
Just sayin
Lol love it! Good progress, trailer is sweet too [emoji1]
Got the tailgate made. A close examination of the pictures will reveal my opening ended up being narrow at the top. It's about 1/4" in on each side. But it works. Hard part about aluminum fab, it's easy for stuff to go out of square.
I cut the threads off long bolts to make pins at the bottom of the tailgate and those drop into holes. Then the barrel bolts hold the top in. We will use a clip to keep the barrel bolts from vibrating loose. The whole tailgate just lifts out, it's not hinged or anything like that.
License plate bracket and light. The bracket is a hinge because the plate will hang down below the frame. Hopefully this will allow the plate to swing up if the tail of the trailer drags.
The bracket for the light was bent out of aluminum. It is lit with a small LED module we would use in a sign.
Got the inspections done so hopefully tomorrow I can get plates for this thing and put it to use.
They actually look for the light now with the inspections. Probably a good idea on pre-bending the plate. After I typed that post above it occurred to me the hinge doesn't help if I back into something. I do kinda like the fender idea. Maybe I'll move it there once I have the new fenders.Good Idea on the license plate. I mounted mine to the fender of the trailer back when it was new. Never had a light, never been asked about it or stopped for it. So if it becomes an issue with trail damage just mount it there. Bending it is fine also IMO.
And I would take the plate once it's on and just bend the bottom of it around that bottom tube. It's going to happen in short order anyway when you back it into something so you might as well know when it happened![]()
Yes. The only thing the small trailer saves me is I don't have to have a weight ticket to prove it's under 2000lbs. If it was over 2000lbs I would have to trailer brakes as well. Incidentally, adding up all the materials the trailer weighs just under 500lbs.Do all trailers in CO need to be licensed? In UT a trailer that small wouldn't need to be registered.
Didn't we all.Yeah, it is true I did some dumb stuff back in the day.
Also, maybe you all have some tips on where to look for the connector. This is my first TBI truck so I don't have a lot experience with it. I was just looking in the area around the distributor/back of the motor.
There was electrical tape wrapped around the plug that had been on there a very long time.
