y5mgisi
1 ton status
That should prevent any future problem.
I made the factory shifter work with the 1/2 clocked tcase in my K5. It worked okay but it took some fiddling to get right. I also made a 2" spacer between the shifter and the floor. I felt like that helped account for the increased height of the tcase.I'm wanting to do the Art Carr/JB shifters for my TH700R4 and NP241. How hard do you thing it would be to get the NP241 shifter to work with a clocked t-case? Is there room to rework the original cable bracket or would another have to be knocked out?
Also, how is your transmission/t-case crossmember holding up? I'm wanting to use the same design for mine but wanted to check and see how yours was holding up.
Awesome truck man, I love the crew cabs.![]()
I really like my fan controller that I got. Haven't really put it to the test to much just running in my driveway and down the street a bit but seems to work rather well.
I will let you know how it is working this summer, I am trying to fall into another set of tires so that I can drive this thing on the street and not kill my 40's.
Will that run 2 fans or, in my case, 2 speeds? I would love to have a setup that would run 2 different heat ranges with just 1 sender.
I like this. Going to put a windshield back in it?
Martin
A good hose and some good clamps are a good investment so you don't have to deal with what we did on the trail....twice (actually 3 times if you count the weekend before that on Eagle Rock trail too
