Man, from a couple dings/dents, to totally modified by nature (sounds like a cologne brand). They say chicks dig scars...
Well I don't know how many chicks would dig not being able to open their door.Man, from a couple dings/dents, to totally modified by nature (sounds like a cologne brand). They say chicks dig scars...
I know my wife doesn't appreciate it.....
After Saturday I've started planning to try and do a rear ARB a year from now.My blazer does the ass end slide to the side as well when I loose traction. I would agree that it's the locker causing it. I am sure you are a lot lighter in the rear than the front as well since your WB is so long and that may be aiding it too. I think the only fix to that is ARB in the rear where you can turn traction off....but as you know that's a lot of money.
Also, how did you feel those tires were doing for you in the snow? Since they are pretty much a street tread, so you think you could have been better off with a meatier tire on there (referring to the ass end slide issue)?
I don't feel like those are too bad of bruises for a long truck you still wheel. I say fix the door handle and put a wrap on that whole truck.....just cover the dents up that way!!!
You would think the trees would respect a big truck like that going thru and get out of your way. Trees can be so stuck up. LOL
Well I don't know how many chicks would dig not being able to open their door.I know my wife doesn't appreciate it.....
The tires actually did pretty good. Definitely seemed to do no worse than the Swampers on the FJ40 or the BFG m/t's on the other 2 rigs. At the end of the trail Saturday I was able to bust through fresh snow over a foot deep for several hundred feet. Based on the way they are wearing I think they are a softer compound. Even though they have a highway tread they are stamped "Not for highway use". These are old racing tires I bought from ORD.
If I had a desire to do more snow runs it would be interesting to play around with trying tire chains and adding weight. However it will probably be a while before I'm ready to do another serious snow run.
And weight. With it being fresh snow it was pretty soft and easy to dig through.Haha, yeah I hear ya there. Probably take a break from the snow runs for a little bit after that one.
That is interesting about those tires. The more I think about it, I guess with that much snow, tread probably doesn't make a difference, its all about the size of the tire at the point. The larger the tire the more ground clearance you have to be able to bust through deeper snow and not have your diffs act like boat ancors.
For comparison to Warn Premium hubs, the Yukon hubs don't stick out near as far.
These have the bulge seat so they end up being taller than regular factory lug nuts. With the plain old factory nuts they don't look like the studs are too short.I was wondering if you plan on putting longer wheel studs on your rig. I'd be nervous as hell the lug nuts not having a thread or 2 sticking out...
I talked with my buddy that was with us and he has a gov-loc in his K5. He didn't have nearly as much trouble with sliding sideways. The only time it was an issue for him was when he was stuck. The time I slid off the trail we were just moving along no getting stuck. So yeah, being locked up definitely makes a difference then.My blazer does the ass end slide to the side as well when I loose traction. I would agree that it's the locker causing it. I am sure you are a lot lighter in the rear than the front as well since your WB is so long and that may be aiding it too. I think the only fix to that is ARB in the rear where you can turn traction off....but as you know that's a lot of money.
At some point around 1 or 2 AM the give a shit meter gets real low.
I don't know I've seen the Bent 72 and I'm not near that far.
