You need to spend your spare time making stickers.
Maybe you need a fan stickerI have a guy for that. Honestly one of the things most rewarding things for me owning a business is providing people with good jobs.
I would probably trim the shroud before buying another fan clutch. The body saw will be easier to control, but I wonder if a small cordless circular saw, used from the inside would be a straighter cut.Just take a body saw to the fan shroud, because you are to lazy to move the drive train back that inch.
I am really no help.
Huh, well I was serious about trimming the shroud. I saw an article about it back in the nineties. Even did it on a couple myself. The old '72 K5 worked well with a 6.0 vortec fan on a TBI clutch and pump, where it originally had a short water pump and 4 blade fan.I was joking about cutting the shroud. Not about moving the drive train.
I was thinking that could be true.I bet that it will be a pain to bolt up a low profile clutch with the fan spaced back. Possibly will be frustrating when you change fan belts too.
While I understand this idea, if it doesn't work as is, and other options either make things inconvenient or a lot of work, I would cut it. It isn't like he is trying to keep the resale value of the fan shroud. Moving the drivetrain back to save cutting 3/4" to 1" off of a shroud is not the direction I would go. Why run the engine closer to the firewall, IF there is room? How close is it already? And how many holes need drilled to do it? And driveshafts? Yeah, fan shroud would get worked on in my truck, if the whole perimeter is consistent to allow trimming. But not my truck here.Considering the 6.2 big shroud don't grow on trees I'd shy away from cutting.
It's not the resale value. It's the fact that if the cutting does not net the desired results he's got to find another expensive, hard to find shroud. Plus because the radiator is so big to start with those shrouds are fairly narrow. Peeling an inch off isn't going to leave much left.While I understand this idea, if it doesn't work as is, and other options either make things inconvenient or a lot of work, I would cut it. It isn't like he is trying to keep the resale value of the fan shroud. Moving the drivetrain back to save cutting 3/4" to 1" off of a shroud is not the direction I would go. Why run the engine closer to the firewall, IF there is room? How close is it already? And how many holes need drilled to do it? And driveshafts? Yeah, fan shroud would get worked on in my truck, if the whole perimeter is consistent to allow trimming. But not my truck here.
Since I am the one that brought it up, I said if finding a shorter clutch is not an option and not wanting to move the drivetrain back, he could trip the shroud.It's not the resale value. It's the fact that if the cutting does not net the desired results he's got to find another expensive, hard to find shroud. Plus because the radiator is so big to start with those shrouds are fairly narrow. Peeling an inch off isn't going to leave much left.
If he gets a shorter clutch it should give the same effect anyway.
I think it's Classic Industries, but one of the websites that sells square body stuff lists new versions of the shrouds, but they aren't currently available. If I need, @kennyw has a shroud I can buy, but I hate to spend money I don't have to. Plus I hate hogging up 2 of these when someone else might need one.Ya, I knew that you weren't worried about resale, just a sarcastic comment.
And I would bet that @mrk5 wouldn't get all crazy trimming it and make it unrepairable. It wouldn't be that bad in my experience to put the piece back on, just would take work to make it pretty.
Sounds like one of these should get a mold made to be reproduced in fiberglass. I have one for my old trucks that a buddy made years ago, and he then made me one for a spare. Lots thicker than original!
