I needed larger holes.
Boy, there's a joke there somewhere.
@Desert_K5 I need cup holders, I see some of those in my future.
I was concerned about how to word the post.Boy, there's a joke there somewhere.
@Desert_K5 I need cup holders, I see some of those in my future.![]()
It does get a little support from the shifter, so it doesn't have to carry the full weight.Let me know how they hold up. I've beat on the single one in my blazer and it's hanging in there. Thanks for giving me a shot, I appreciate it!
#links&coiloversYou need a smoother riding truck to keep the coffee spills to a minimum.
I was not going to say it. Seams a little excessive to not spill coffee.#links&coilovers
One could also say wheeling a crew cab long box on jeep trails is excessive too.I was not going to say it. Seams a little excessive to not spill coffee.
Now you are thinking. Might as well...Maybe just need links and coilovers for the cup holders.
Maybe Nate is so powerful he sheared the pin messing with the rotor. Aside from that, I would think it would take a lot of RPM to shear one. I rarely rev the motor over 3500, and I don't think I was doing anything more than that. Maybe it was revving it up, spinning tires, and then letting off the gas several times trying to bust thru? You wouldn't normally rev a motor up and then let off the pedal quickly.Pin, 2 washers, gear
Never had one come apart. If it broke, the pin should have parts sheared off in the gear or shaft, right?
If it sheared off, what cause it to stop enough to shear it?
I had one pin back out. Ended up replacing the gear. Caught it before it did this.
I was wondering if a gear could break like that and spin the pin out. I'm very curious to see what it looks like in there. But not today. It's Easter and I want to relax.Broke the gear at the pin holes and the pin spun out. If the gear stripped, it would still be there with the pin. At least 2 pieces of gear should be found. I have seen clean breaks like this not affect the engine. Because it was instant catastrophic failure of the gear. The engine did not have a chance to travel the parts through it. Cranking it should not be enough to hurt it. You just have to be sure you found everything. Put the pieces back together as you find them.
