That's just weird. If it bends easily I'm wondering if fuel slosh could be a legitimate possibility.
I have a new theory now and it is probably what happened to both of you.Well, well, well, if any of you follow @the_blaze's Plan B build thread, this will look quite familiar.
A bent sending unit! It looks exactly like the one he pulled from his tank. I definitely did not cave in the bottom of my tank. The drive shaft would be living in the tank if I did.
Here's the depth of the tank. It's measured from the long end of the square that starts at 24".
So it's basically 11-7/8". The bent up sender measures well short of the bottom and about 10-1/4".
I can't see any way the tank was sucked or dented in 1-5/8" without any outward indication. I can push down and get minimal movement on the top of the tank, certainly no where near 1-5/8".
I pried on the baffle tray with the square and it's solidly afixed.
You can see a mark where the bottom of the sender scraped on the tank.
I could easily bend the tube back to straight and the sender sits down into the tank easily as referenced in the picture below:
I could move the locking ring around 3/4 of the way to fully seated by hand. That confirms there is plenty of room between the sender and the bottom of the tank.
The only working theory we've come up with is the tube is so weak it's getting bent by fuel slosh.
How air tight is your tank?
When you open the cap when cold does it feel like it was vacuum?
That could pull the flat part in and cave in easily one or two inches and spring back.
Probably little bit on top and little on the bottom.
We live in warm weather.I thought about that however that's the reverse of what I've experienced on my trucks. Usually it's positive pressure......
Notice that the crush is identical, they got compressed to the same length.I thought about that however that's the reverse of what I've experienced on my trucks. Usually it's positive pressure......
I didn't think about the pump creating the vacuum but it makes more pressure than just extreme cooling.So to me it seems like the big scratch in the bottom of the tank is a clear sign that the bottom of the tank hit the sending unit and bent it up.
Is the vent tube open in the sending unit? See if it flows air? It shouldn't build pressure(or vacuum) if you have an open vent, something is blocking the vent. And if it wasn't hit from the bottom, it's possible with the vent being plugged as the pump sucks fuel out, and air can't come in, it's collapsing the tank...
I'm thinking the vent tube in the sending unit isn't actually venting like its supposed to, or the fuel cap, or both. You are getting a vacuum, that pump can make a lot of pressure, and if the tank can't let air in to displace the volume of the fuel that was removed, something has to give, it doesn't take much on that much surface area. If the top of the tank is 30x30 for example, even 1 psi of vacuum is 900 lbs of force on the top and bottom of the tank.
Get the vent working properly, and your issue will likely go away. Don't brace it, or you will put all that force onto the one point of the brace instead of spread out and likely kink or bend something permanently.
Which way? Can air enter the vent line? Or is that the caps job? I'm not sure which is supposed to let the air in, but I feel like whichever it is, it's surely not happening, especially seeing those dimples there from the top likely bowing in too, to the point it kinked the sheetmetal. I know with an old mechanical pump, where it only sucks the fuel, a blocked vent can actually prevent the fuel from being drawn out, or drawn out fast enough to make decent power.The vent line isn't plugged. I can blow 60psi air threw it. It's pretty difficult, but I can blow into it. I certainly wouldn't say it flow easily.
I did notice these interesting dimples on the top of the tank.
I scrolled thru pictures during fabrication and I can't see the dimples in those pictures.
So you found your culprit.I'm thinking some of the problem may be not having the evap canister installed. That watchya-whoseit might only flow with a vacuum on the engine side being drawn thru the evap canister.
So it would seem. Might have been fine if I had the evap canister installed and properly connected. I just hate having to deal with all that vacuum plumbing if I don't have to.So you found your culprit.
