DANG! this is exactly what I want to build for my truck!
A big block? It’s about time you grew up
Hahah, I knew this was going to happen. Honestly the ls rips in the truck but more cubes and torque would be gnarlyA big block? It’s about time you grew up![]()
Thanks for the explanation. Knowing how some L29 guys (online guys) were tripping over themselves to get away from the 4x crank signal I was wondering what some of the issue was. Really I think the biggest thing is getting away from the earlier “black box” ecm that most of the aftermarket tuning software companies like EFI live or hp tuners don’t have any ability to communicate with it. So if you don’t want to go with a Holley terminator setup and want a gm ecm you have to at least get to the 0411 controller and that forces the 24x crank signal.
The terminator just sounds like an easier deal all the way as it looks to be more user friendly to a tuning noob over HPT or EFIL.
Thanks! I was thinking it would be hard to install alone. The C10 isn't that bad, but it's a lot harder to get to the bellhousing bolts with the tcase obstructing the view. If this truck wasn't so tall already, I'd put a 1" body lift in.If you need any help installing the L29/L21 I can drive up and help on the weekends.
Doing hoods alone kinda sucks but you made it look easy.
The Cherry Bomb with a 454 would have been pretty sweet!Nice! I am glad you got that engine sold because getting it as a Christmas present to myself was tempting.
If I ever do another L29 it will be spec'ed out like Rob's buddy Ian built.The Cherry Bomb with a 454 would have been pretty sweet!
I had the same problem with my k5.Crazy, mine do the same… it must be a long bed thing cause our crossmember bolts come loose too!
