Just pound down the high spots and skin right over those doors. It will be like armor plating. Never mind the added weight.
The damn rear doors are so hard to work inside of, I don't know if I could get a backer in them.On the dent work I have put part of a sheet of plywood or steel on the inside so the ball only pushes on the metal you want to push.
That is the theme for this truck!.....Never mind the added weight.![]()
Awesome! Idaho Springs/ Georgetown area?
Yep. Wasn't as snowy as previous trips this time of year.Spring Creek maybe?
Yeah, that spot kicks my ass. Since the drop is on the passenger side, it just looks to me like I'm close to the edge regardless. It's not until the passenger(s) start yelling i realize we've gotten so close.That’s not the first time you’ve tried to drive off the mountain in that exact same spot.
The worst part was waiting for Nate to pull out the winch and hearing rocks tumbling down the mountain side. I was wondering if the road was going to hold together long enough.scary! That's a long way down!
@doubletrouble had to rerig the winch to pull his seat out.Pucker a bit?
Martin
I would now with the 2' shorter wheelbase and no bed sheet metal. I don't know why I have so much trouble with that spot on Spring Creek. Like I don't even think about it when I'm driving up it. I guess maybe that's the problem, I need to pay more attention there. Maybe I'll remember next time.You've been to that spot before, but you wouldn't try the Intimidator???
My leg pressing the brake pedal was shaking.Pucker a bit?
Martin
I was concerned that if changed anything like what gear it was in or put it in neutral or let off the brake, all hell would break loose - literally. Plus every time we bumped the winch, it would put a load on the engine through the alternator and cause the idle to bump up which would cause it to try even harder to over ride the brakes. That's a problem with a big block and both transfercases in low.You worried too much. You could have put it in neutral to hold until they helped you or reverse and got yourself out.I would now with the 2' shorter wheelbase and no bed sheet metal. I don't know why I have so much trouble with that spot on Spring Creek. Like I don't even think about it when I'm driving up it. I guess maybe that's the problem, I need to pay more attention there. Maybe I'll remember next time.
My leg pressing the brake pedal was shaking.I was concerned that if changed anything like what gear it was in or put it in neutral or let off the brake, all hell would break loose - literally. Plus every time we bumped the winch, it would put a load on the engine through the alternator and cause the idle to bump up which would cause it to try even harder to over ride the brakes. That's a problem with a big block and both transfercases in low.
Oh yeah, it always feels worse inside the truck. It felt to me like the driver side tire was barely touching. Like I said, the sound of falling rock was really getting to me.You worried too much. You could have put it in neutral to hold until they helped you or reverse and got yourself out.
You still had 3 wheels on solid ground and it was pretty flat.
Except if you had a bad shifter like me in Moab and you go to reverse and it goes in neutral and you roll it![]()
