I was hoping that I could keep my axle approximately in the stock position when swapping to 52" leaf springs, such that my predetermined pinion angle would be within a couple degrees of perfect. Does that seem realistic
With the B52 set-up you could dial in axle location. Getting the axle located isn't going to be the hard part of your build.
I was assuming the distance between the C's was set by a lip on the exterior. That is to say, I assumed they could only be pressed or beaten on so far. Is that incorrect?
I wouldn't assume anything, and to go further, even if there is a lip...can you be sure it's hard up against that lip after being rotated? My thinking on kingpin to kingpin dim's is for confirmation purposes. It's not likely to get one or both C's slightly cocked, or not against the lip (if it's there) but having KP dim's will put your mind at ease.
While I got you here, how should I reweld the C's (I know I am getting ahead of myself). Once again, I have heard multiple scenarios. Here is at least two of them.
1. Just weld it, approximately 1/4 of the circumference at a time, alternating sides.
2. Preheat significantly - stitch four longer tacks at 0, 90, 180, & 270 degrees from your arbitrary starting point. Allow to cool, repeat the process shifting 45 degrees from initial, cool, repeat until fully welded then weld over the stitched weld.
Once you're satisfied the C is exactly where you want it tack in 4 places 90 degrees apart. Re-check all dim's. If everything is right where it should be burn about a 1/2"-3/4" fillet into each tack. Ideally you would stand the diff upright so you're welding in the horizontal position.
Pre-heat the C to 250 F. I would weld it in a back step pattern. Weld 90 degrees of the circle (3 o clock to 6 o clock) then the next weld would be from noon to 3 o clock etc. Welding it this way you finish a weld by burning into the start of the previous weld, helping to negate a big crater at the stop/start. This method also greatly equalizes the heat affected zone, and reduces distortion a fair bit.
Interpass temp shouldn't exceed 350 F. You should ideally have two temp sticks, a 250 and a 350.
Bit of an oversight, but what is your welding set-up? I hope you have something with a bit of jam to it. E70-S6 microwire in .035" would be fine, but it does depend on machine. 7018 stick would work too...
Likely you'll do three passes to get to the appropriate fillet size. I'd aim for a 3/8" fillet. After welding, let it air cool if ambient is not too cold. Cast steel isn't anywhere near as fussy as cast iron, but it can warp. Even "through heat" is the key to keeping the C's true. If you're worried about it, you can throw a welding blanket over it to slow the cool down time.
Hope that helps a little.
