As I mentioned, it sounded like an electrical issue with the trans. After more research, I decided to start investigating. Started with the simplest things first. Checked all the connections and the fuse.
All but one of the connections looked good. The one that didn't look good just looked dirty. Figured I would clean it out with a pick. Crawled out from under the truck and checked the fuse while I was up and it was fine, other than being a 30A fuse when it's supposed to be a 10A.
Got back under and cleaned the dirty plug. I thought I'd test it after that and IT SHIFTED THROUGH ALL GEARS!!! I guess that one dirty connection was the problem? Praise God that it was an easy fix.
Now on to the parts burb...
As I mentioned, I just stumbled across it and couldn't pass it up. This will change the plans just a little on the build. I'm probably just going to use the frame from it since it would mean not cutting the floor, like I would have had to do on the other frame.
It has lift springs on it, but not sure of the height, maybe 4". Plan to add a 1" body lift and 1" zero rates. Looks like it has 56" rear springs, so I'm going to flip them around to stretch the wheelbase.
I'm also probably going to steal the doors off of it since they're in better shape than my current ones.
A question for the Brotherhood:
Would it be worth it to use the spare frame to box the rear of the burb frame?
One of the reasons I got a 1-ton was for the beefier frame. Obviously the burb frame isn't quite a strong.
The reason for just the rear, is that I plan on welding supports for the sliders to the frame and having an engine cage up front. I do plan to have some sort of partial cage/roll bar looking thing on the back, though.
I'm debating as to whether it's really worth it or not as this isn't going to be a full fledged hardcore wheeler. Sure, it will see some hard stuff on occasion, but in all honesty, I'd be happy if I went wheeling 5 to 6 times a year.
Lastly - There has been another development for this. I have something in the works for the drivetrain... *coughbehemothstrongboxcough*
For now, that's all the info I'll give.
