ya, the burb has the same wheelbase of a standard cab long bed truck, and the crew cab is a lot more. burbs up to '87 were 129.5" and '88-'91 were 131.5"
Umm, almost, but no. Burbs are the same for '73-91; the pickups did change for '88. See below.
I have been looking for a 91 crew cab without any luck. So I am planning on building one. Dooes anyone know if a 91 Suburban frame is the same as a crew cab?
As mentioned, sixpacks are a totally different animal than a Burb. Also note that sixpacks all have the one-tone frames, i.e. taller and thicker section, and the narrower spring spacing in back.
Also, take a good look at Burbs, and see how close the back tire is to the rear door. The rear axle on a Burb is WAY forward when compared to the pickups, so it has a longer rear overhang than it would if the axle was centered. (Presumably this was done so soccer moms could turn their Burbs more easily
Lessee, some numbers:
73-91 Blazer 106.5" WB, 184.5" LOA
73-91 Suburban 129.5" WB, 218.5" LOA
73-91 pickup crewcab 164.5" WB, 244.5" LOA
73-87 pickup shortbed 117.5" WB, ~191.5" LOA
73-87 pickup longbed 131.5" WB, ~212" LOA
Overall lengths for the regular cab pickups are a bit vague due to bumper options. Remember that the crewcabs, Blazer and Burbs kept the old body style for 88-91.
Now, there ARE some odd length crewcabs, which were sold as cab and chassis trucks, i.e. no bed. There are a few different sizes AND some were modified after GM made them, so the only way you'll know what specific wheelbase any such truck has ... is to break out the tape measure
Oh yeah, and a crewcab is fricken huge, and has the turning radius of the Exxon Valdez. Ask me how I know
-- A
