91 Jimmy
Virginia
I have a 91 Jimmy with a 3 inch suspension lift. I’m currently running 33x10.50s with zero clearance issues. Any insight on if I’d have to trim/run spacers to fit 35x12.50s with no lift modifications? Also, with a fuel injected 350/700r4 and 3.73 gears how will that pull 35s?
15x8 stock right now but might move to a 10 inch wheel. No offset right now but would be willing to buy spacers
The 350 will move the truck with 35's and 3.73's, it just won't do it fast.
If you are just driving around town the 35's will clear most of the time, but can and will rub on each end of the wheel opening if you actually flex it out off road.
