Can you give me an overall height and width of those shifters/base. I'm working on getting a doubler (well, reduction box/205) in my K5 right now and I think that style shifter will work the best
So is it going to be driving soon?......![]()
@Kay86K5 Here is the dimension pic from the JB Fab site, if you need something different let me know.
my bad...carryon@Kay86K5 Here is the dimension pic from the JB Fab site, if you need something different let me know.
Are you running a center console?
Yeah, I found that as soon as I wrote the freaking post...my bad...carryon
I have the original factory console but I doubt I'm going to use it. I'm thinking I may need the opening between the seats for "easier" access to the rear seat once the cage is eventually complete, I plan on using diagonal bracing like Greg72 discussed on his ( like this > \_/ with some space between the support legs at the floor, not ideal but more practical).
only reason I ask is because you may want the sifters back and closer to the driver if you're not running a console. Otherwise you'll be reaching for them which is impossible if you end up with a harness down the road.
