didnt you just swap that in?
Yes, sir. My whole axle swap was a mess. Should have just regeared.
Installed the 14ff, and learned the gear setup was all messed up, pinon started leaking, etc. Ended up having to have all the bearings swapped and the gears setup again.
Then had all sorts of shock issues, because I didn't realize i had a 2wd 14ff, with different shock mounts. Had i just cut the shock mounts off and changed them, I could have run my old shocks.
Now, the front axle. Thank god these tires were only about 25% to start, or i'd be PISSED.
Going to keep an eye out for another center section.....
Debating having an alignment shop check it out, just don't want to waste the $80. I checked it with a tape measure, and its seems close. Don't think it would wear on the outsides unless it was WAY toed out, and it drives fine.
That, and i bent the tie rod, and had to straighten it in this whole mess. That would make me think its toed in....but then it would be wearing on the inside....
Tires were wearing FINE on the old axle though.....
Gotta stay focused though. It runs, and drives ok. Will make it though the summer.
