Tony Vickers
- Joined
- Nov 7, 2016
- Posts
- 128
- Reaction score
- 44
http://seattle.craigslist.org/see/pts/5988846597.html
96 Cummins 12 Valve or 6BT. This engine has been completely gone through. All new Cummins upper and lower gaskets. Block was decked and inlined honed to make sure it was true. Crank, rods, pistons have been balanced. New head, Mahle piston rings and pistons, push, tappets,Cummins rods, Colt Cams Big stick cam, New p7100 pump rated at 235HP New +50HP injectors new fluidampr. Rods, mains cam and cam bearing, pedestals and rockers, cam gear, oil pump all have been coated to prevent wear. Top of the pistons have been coated with ceramic to better dissipate Heat. I've got a ton of money tie up in this and she runs VERY strong. The only things not replaced are the crank tappet and valve covers and oil pan and mains. I'm sure I'm missing something and have many other photos. This video was taken as I was breaking it in. Over all it ran at 2000RPM for 45min with oil pressure over 60psi.
Thanks for looking.
Thanks for looking.
