mudbuggy
Smart man, I gotta learn how to quote, and upload pics
Smart man, I gotta learn how to quote, and upload pics![]()
If it suits your needs better, I tapped the back of my A6 for 1/2" NPT. There is enough meat there if that works better for you.![]()
I thought about this actually, but figured the less I have to touch on the seal the better. The hose/fitting shop I go to should be able to slap fittings on here pretty easily. I'm scared of leaks!
The a6 just has an o ring under the head, should be pretty easy to replace. Mine was old and I was lazy, so I just used rtv lol. Its been holding up fine though for quite some time now. I figured it was just the oba so I wasn't too concerned if I had to redo it.
Sure you have your supply going to the tank and not to the intake?
Make contact with the clutch with 12 volts the clutch should 'click'. Then at idle you should be able to put your finger over the lines, you'll then be able to figure out intake and supply to tank from there.
Have you added any oil?
All of the above should be done at idle.
Mine will fill a 5 gallon tank at idle less then 3 minutes @ 150 psi.
You ideally need a one way vale between the tank and compressor. To keep the air in the tank so the other piece can allow the compressor to start with no load
An unloader valve it dumps the line pressure between the compressor and the one way valve to allow the compressor to cycle and not stall out.
