TheBeast_88K5
Banned
Did you inherit my luck, when you inherited my axle?...
This thing is runnin' you around, lately.
Ok guys so, question. I'm having a mobile tig welder out soon to fix this. I have the case out and everything, the hole got bigger and now its more like a half moon,and my question is this...After he's done with the welding, I'm going to be left with a rough blob of aluminum right? What's the best way to - shape the new aluminum? I will have to shape it with a good dremell tool or a file? Any advise appreciated!For real... Get a mobile Tig welder to do it!
Simple, and should be relatively cheap.
I would be worried about the strength of that Trans' Case...
If you follow us around, and it's that weak anywhere else, it's gonna break..
*You can "right click" and "copy" pics, then "paste" them directly into posts.
*This is one of the few forums that supports it!![]()
he should fill it all in to 1 solid mass.
then you grind flat / or file flat.
install adaptor for template to drill new hole. then drill it and tap it out.
if hole dosnt go threw then start with a reg tap then finish with a bottom out tap.
good lube and slow and steady when tapping the hole.
That is not why he broke it.Man you have bad luck lol. Curse these old rigs. So i was thinkin.... I know i know. If these 205s are so heavy and only supported by 4 bolts why not run some type of support like my 208 has from the bell housing to the tc? Or some type of hanger? I think avery got some hanger from trail tech fab to hold his doubler up that just bolts right on... May be worth looking into so you dont have this problem again.
It was my fault, I broke itThat is not why he broke it.
It was missing the top 2 bolts and I gave him a couple of pairs to try, one was too long and only threaded for 1" and he tightened it too much and thenon threaded part was forced in the hole and popped it off.
laugh and learn!
