A truck for the "scary suspension" archives
technically yes, some guys do run the slip yoke on the bottom end. I don't remember why though
Slip yoke portion doesn't dent if you bump a rock...the fixed end is weaker so it's kinda better to have it up at the high end and keep it protected.
I lost a rear driveline in Moab because of that. Had I run it the other way it would have survived the small bump it got rather than turning inot a pretzel.
Rene
Rene
Knew there was a reason i run mine that way :D
That and i had no idea there was a difference :haha:
drive shaft
So i can run it backwords so what happens when i drive on the streets does it work the same and will it vibrate?
Rene
Did it look something like this?
That's why I now run the smaller (MUCH harder to dent) side at the axle side, like this:
No problems since.
