aftermarket guages/factory dash
bodacious
Quitman, Mississippi
How hard is it to install aftermarket guages in the factory locations in an 83 dash? I also think I saw a link to a custom dash with the guages already installed on here. Pics would be appreciated. Thanks for the help.:waytogo:
let me know
bodacious...you get good info on this, let me know. I have an 84 and want to get rid of the look and redo the dash/console/bezel and gauges completely.
Yup, either Jeremy or Sweetk30 did the same thing with a dremel and 10 minutes...
I have to find the pic of THE one factory setup i've seen with the gauges done at a nice angle... its a 2 wd truck.. i'll hunt for it...
rivermtnman said:
Here's a pic I saved from a forum in here I once saw...
yup, thats the one... It's the only one i've seen with angle correction....
heres mine.. no angle correction... i dont drive her oin the street much soo didnt feel that it needed done.. i can see the gauges just fine....i used a trenz billet alumin piece that is designed too bolt on over ur existing dash...
heres mine, no angle correction for the 2 main guages, but i only stare at all the small guages anyways.
So if you got a piece of aluminum and copied that bolt on one. How thick should the aluminum need to be to cut the holes at the correct angle for mounting? 1/4" - 5/16" - 3/8" ? I've thought about getting flat stock to make a solid panel, either by making the two bends or possibly 3 flat pieces and then take it somewhere to cut the angled holes for me.
why not just make up an angled piece of tube (wedge shaped) and put it between the front of the guage and the sheet of metal
you would be able to adjust the angle by varying the wedge.
gauge panel
Here are some pics of mine. I used the angle rings on all of them. It makes them a lot easier to see. I cutout the back of the change tray. Got some plastic I found in the garage and covered the opening. Then cut the hole and used angle rings for the tranny temp and fuel pressure.
I usually have a cover on that. Its not blinding in the day cause when it goes off I'm usually not looking right at it anyway. At night it will.
