HellsK10
Registered Member
Some of us have the unfortunate status of starting a membership to a new enthusiasts site with a "please help". Unfortunately I'm one of them. I've been a mechanic for the better side of 10 years and I'm absolutely stumped. Perhaps it's spending too much time focusing on one thing that I've overlooked another...who knows? At any rate, here's the story and the problem:
I bought this 73' Chevy K10 4x4 Pickup with the 350. It has an HEI distributor on it and from day one it was a wiring disaster! I'm fairly sure (the diagrams on this gen of Chevy sucks) that I got all the wiring correct. I have my constants constant and my "runs" only when the key is in "run". There's +12 to the BATT terminal of the HEI at all times. I just replaced the cap and rotor with MSD's set. I pulled the Carter off and threw my 1406 on it for the moment (cause I knew for sure there was absolutely nothing wrong with it). I pulled and double checked the firing order from the cap to the plugs and it's right. I haven't been able to put it at TDC and double check that the rotor points at #1 cause the crank bolt is the wrong one and spins once any torque is put on it (fix that tomorrow). This is the thing...it cranks for days, gets plenty of fuel and I have spark. From where it was I rotated the distributor 1/5 of a turn counterclockwise and it backfired REAL LOUD. I rotated it back about 1/6 of a turn past the original starting point and nothing. If I had a hand I would just throw the timing gun on the #1 to see if it fires near the timing mark, but again...gonna have to wait till tomorrow.
Any ideas? It doesn't matter how outrageous, it may end up coming to whatever that is. It certainly seems as though it's got plenty of compression but I can check the numbers for sure this weekend. In the meantime, I just need ideas.
Thanks. And I'm proud to be part of the lifted Chevy crowd now...or will be when this thing runs.
uh.
